SIM Reader powered by the serial port
by alandsilva on Thu Sep 17, 2009 6:05 am
Is it possible to provide the vcc power supply from the vcc pin from the serial port?? Thanks in advance
alandsilva
Re: SIM Reader powered by the serial port
by mtbf0 on Thu Sep 17, 2009 7:31 am
alandsilva wrote:Is it possible to provide the vcc power supply from the vcc pin from the serial port??
there isn't one. signal levels on a serial port are like +/- 10v.
mtbf0
by djfreeman on Fri Oct 02, 2009 2:15 pm
yes you can....
But the current is low, you have use the pin 4 and 5 to the db-9 ang link to 1n4148...or...take tehe vcc from the USB :) or another external vcc.
see my protobard
http://od-lambda.blogspot.com/2009/09/lector-de-tarjetas-sim-por-rs-232.html
djfreeman
by minerva on Sun Feb 14, 2010 11:47 am
This is basically why we invented USB... and that damn RS232 should be banished.
minerva
by pstemari on Fri Aug 06, 2010 2:56 pm
minerva wrote:This is basically why we invented USB... and that damn RS232 should be banished.
Get back to us on that after you've implemented a USB packet driver.
There's a reason those FTDI cables and chips are worth their weight in gold.
--Paul
A wholly owned subsidiary of:
Persephone: DL R+W+B C 7 X L W C++ I++ T+ A E H++ S+ V-- F+ Q P B PA+ PL
Aldebaran: DM Rt H 5 Y L- W+ C+ I++ T++ A+++ E H++ S+ V+ F++ Q+ P B++ PA- PL--
pstemari
cron
