ExperiMenta
ExperiMenta
by uberhund on Fri Jun 29, 2012 5:07 pm
The result of an afternoon's work gilding the excellent Adafruit lily.
Yellows and greens are extensions to digital pins 2-13 on the right, and analog pins 0 to 5 on the left. Reds and center black header are extensions to V5 and gnd, respectively .
White is standard, general purpose prototyping area.
Menta with additional breadboarding features added
ExperiMenta sized.jpg (217.34 KiB) Viewed 2836 times
Hacking is an addiction. Arduino is the gateway drug.
uberhund
Re: ExperiMenta
by ransomhall on Thu Jul 05, 2012 8:37 am
Awesome. Where did you find the colored female headers?
ransomhall
Re: ExperiMenta
by uberhund on Thu Jul 05, 2012 2:42 pm
Would you believe I spray painted standard black headers, first with white primer, then with the final coat, to get the colored ones?
Sticking the header into some conductive shipping foam helps position it for spray painting on all sides, and also shields the metal leads from the over spray.
A bit obsessive, perhaps, but the alternating colors really speed up component placement and reduces the alignment errors I was previously making.
Thanks for the kind words.
uberhund
