Winter Storm Juno: Blizzard! ORDERS NOT SHIPPING TODAY. All shipping and UPS service guarantees are suspended due to weather and blizzard conditions.
What is the minor edit of the Uzebox core?
Moderator: adafruit
by nic_rf on Thu Mar 12, 2009 10:45 pm
I have question, what is the minor edit of the Uzebox core? Because, the version is available, and it's possible to download : Here
Information Topic on Uzebox
Plz
Thank you
Bye
Excuse me for my bad English I am french...
nic_rf
Re: What is the minor edit of the Uzebox core?
by uze6666 on Sat Mar 14, 2009 10:10 pm
What do you mean by "minor edit"? You can also clarify in French, cuz i'm also French... :)
Uze
uze6666
by nic_rf on Sun Mar 15, 2009 12:06 pm
Okey, sa va être un peu plus facile,
Bon, sur le forum de uzebox, la version 4 du firmware est sorti. Mais sur le site de fuzebox, la version disponible est la 2e. Donc j'ai penser installer la dernière version sur ma futur fusebox(j'attends toujours le pièces), mais bon, il est inscrit sur le site web : This code is a minor edit of the Uzebox core. Donc, la question était ; quel est ce petit changement, pour pouvoir l'intro duire a la version 4...
Svp
Merci
nic_rf
by uze6666 on Sun Mar 15, 2009 11:54 pm
Ok, la petite modif concernait l'activation de la pin CE du AD725 (sur mon prototype, la pin CE est a VCC). Depuis la version 3, tu peut utiliser n'importe quelle version du firmware pour ta Fuzebox sans problemes. En fait c'est pas vraiment un firmware, mais plutot un 'kernel'+librarie.
Hehe, c'est amusant de parler francais sur le Net des fois... :mrgreen:
Uze
English translation: The change concerned the activation of the CE pin of the AD725. Since V3, the change is incorporated and you can use any versions of the firmware for your Fuzebox. In fact, it's not really a firmware, but a 'kernel' and library.
uze6666
by Nender on Tue Apr 07, 2009 12:50 pm
So does this mean that I can compile and download the latest uzebox firmware and it will run with no problems?
Nender
by uze6666 on Tue Apr 07, 2009 3:28 pm
Sure, if the user code is made for it. In other words, using the new kernel with games made ages ago will probably not compile due to a lot of functions being improved/removed/changed as time goes. If you download branch v4-beta in gCode, all demos in there uses the new kernel so everything will be honky dory.
Uze
uze6666
by Nender on Tue Apr 07, 2009 5:24 pm
Good to know. I don't know why I was under the impression that they weren't compatible. Thanks for the prompt response, and thank you for all the time and energy you have put into this project.
Nender
