DASA not working
Moderator: adafruit
DASA not working
Postby Areshiones » Fri Apr 03, 2009 1:08 pm
I am using a USB-Serial cable that is connected to the DASA kit you sell. The DASA is connected to the Fuzebox. The Fuzebox is powered up and I run avrdude to try reading from the chip but I am not able to do it.
I already tried video, audio and bootloader so everything seems fine. What can I do to communicate with the Atmega?
P.S. When I "unplug" the DASA from the board the LED blinks three times as if a reset is being performed
Areshiones
Re: DASA not working
Postby adafruit » Fri Apr 03, 2009 1:38 pm
unfortunately the dasa programmer is too 'crappy' to program it :( you would need to put a buffer on the programmer lines because they are being too dragged-down by the SD card resistors. alternately you can just 'clip' the SD card resistors. i dont think SD support has been really nailed down anyways
Postby Areshiones » Fri Apr 03, 2009 1:51 pm
In this case, if I use the USB TTL would mean I won't have this issues?
Areshiones
Postby adafruit » Sun Apr 05, 2009 10:31 pm
yes it would be OK, assuming that you have a kit or a preprogrammed fuzebox chip with the bootloader
Return to Fuzebox
Users browsing this forum: No registered users and 1 guest
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
