Storing games?
Moderator: adafruit
Storing games?
by BillColeman on Mon Dec 20, 2010 12:36 am
I'm thinking of buying the Fuzebox starter pack from you, when it comes back into stock.
Background: The bad part is that I have no experience at all with console games (too old by the time they were invented) and I have no experience building digital electronics. However, I do have about 35 years of experience with computer programming (including a PhD) and also I've previously built a pretty complicated Heathkit audio receiver kit. So I'm reasonably confident I could put the kit together and that I could program games with it.
My question is this. After building it, I wanted to let my 8-year-old grandson play with it. He'd probably love the games available on the Uzebox site.. However, the process for loading games into it seems much too complex for an 8-year old. So, question: Is it possible to leave several games loaded into it in a way that would allow him to switch between them with reasonable ease?
2nd question. I was planning to give him an old ('80s-vintage) Sony color TV that has composite video in. Am I correct in assuming that would work?
Bill
BillColeman
Re: Storing games?
by uze6666 on Mon Dec 20, 2010 6:19 pm
Hi Bill,
If you assembled a Heatkit, you should be fine with the Fuzebox, specially since the only surface mount part is already pre-soldered.
Absolutely! You can flash on the device a special program called the Uzebox Gameloader. It allows games to be loaded and flashed directly from the SD card using a nice menu. See this thread on the Uzebox forums for more info.
All old analog TVs sets I've tested worked fine.
Hope that helped,
-Uze
uze6666
Re: Storing games?
by BillColeman on Mon Dec 20, 2010 6:30 pm
Uze,
Thanks. Yes, that's enormously helpful.
Best wishes,
Bill
BillColeman
