Can't get avrdude to program my fuzebox....
Moderator: adafruit
Postby aburzillo » Sun Dec 28, 2008 2:17 am
I'm using the usbtiny programmer with my fuzebox. I'm programming it from a mac laptop, using the command:
avrdude -c usbtiny -p atmega644 -U flash:w:megatris.hex
and it returns with an initialization error rc = -1
do you know what may be wrong? I have colorbars and everything (and I really feel like playing some megatris...)
Thanks for your help!!
Anthony
aburzillo
Re: Can't get avrdude to program my fuzebox....
Postby adafruit » Sun Dec 28, 2008 12:31 pm
is the fuzebox powered? do you have the cable in the right way? try the other cable, and also check that its in the right way
Postby aburzillo » Sun Dec 28, 2008 2:27 pm
yes i have already tried both of these
aburzillo
Postby adafruit » Sun Dec 28, 2008 2:58 pm
hmm, does -anything- happen? does the fuzebox reset or anything?
also, just to be sure, you can program -other- chips, right?
Postby aburzillo » Sun Dec 28, 2008 4:31 pm
Actually, I can't program other chips.... :oops:
Have any Ideas of what might be wrong with the programmer?
aburzillo
Postby adafruit » Sun Dec 28, 2008 5:09 pm
umm, you should probably post about that in the usbtiny forum ;)
Postby aburzillo » Sun Dec 28, 2008 7:20 pm
ugh
I take it back, it can program other chips, so it must be a problem with the fuzebox....
aburzillo
Postby adafruit » Sun Dec 28, 2008 7:25 pm
if you dont have a spokepov kit, try the jumper hack, detailed in the usbtiny assembly instructions
Postby aburzillo » Sun Dec 28, 2008 7:44 pm
By the way, if I overide the test, I get:
Macintosh:~ ant$ avrdude -c usbtiny -p m644 -F
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x000000
avrdude: Yikes! Invalid device signature.
avrdude: Expected signature for ATMEGA644 is 1E 96 09
avrdude: safemode: Fuses OK
avrdude done. Thank you.
aburzillo
Postby aburzillo » Sun Dec 28, 2008 7:56 pm
ladyada wrote:if you dont have a spokepov kit, try the jumper hack, detailed in the usbtiny assembly instructions
well, I've already confirmed that the usbtinyISP works, so how would that help?
aburzillo
Postby adafruit » Sun Dec 28, 2008 10:14 pm
the output resistors used when programming spokepovs might be fighting the resistors that connect to the sd card. theres a good chance thats the issue
Postby aburzillo » Mon Dec 29, 2008 1:19 am
I can't find where this hack is detailed do you have a link?
I looked for it on the usbtiny page and on the spokepov page with no luck.
Thanks a million for your help!
aburzillo
Postby aburzillo » Mon Dec 29, 2008 11:36 pm
so what do you think the problem is? I really want to get this working...
aburzillo
Postby aburzillo » Mon Dec 29, 2008 11:38 pm
should i post pictures of the board?
aburzillo
Postby aburzillo » Tue Dec 30, 2008 4:55 pm
It is definately my usbISP that is causing the problems, I will look into it
aburzillo
Next
Return to Fuzebox
Users browsing this forum: No registered users and 1 guest
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
