avrdude/FTDI upload problems...
Moderator: adafruit
Re: avrdude/FTDI upload problems...
Postby adafruit » Thu Jan 08, 2009 12:33 pm
the ftdi cable is a bit faster too, actually.
i'm somewhat suspicious of the FTDI driver, since it doesnt seem like the cable 'works at all' under vista
do you recall which driver you downloaded?
Postby jleemero » Thu Jan 08, 2009 9:02 pm
ladyada wrote:the ftdi cable is a bit faster too, actually.
2.04.14
Supports FT2232H, FT4232H, FT232R, FT245R, FT2232, FT232B, FT245B, FT8U232AM, FT8U245AM.
For Windows 2000, XP, and Vista.
jleemero
Postby Dan_K » Fri Jan 09, 2009 11:32 am
I've just tried avrdude on my Windows XP laptop which I've gotten back and I'm getting the same error that I get on my Vista desktop. Looks like the problem could be with the chip or the board?
Dan_K
Postby jleemero » Fri Jan 09, 2009 1:09 pm
Dan_K wrote:I've just tried avrdude on my Windows XP laptop which I've gotten back and I'm getting the same error that I get on my Vista desktop. Looks like the problem could be with the chip or the board?
I think that's more likely.
I'm getting a similar, though not "identical" error on my Linux laptop.
jleemero
Postby Dan_K » Sun Jan 25, 2009 10:24 am
I've ordered a couple more chips and I can connect to the new one. Looks like I somehow managed to bugger up my last one. At least I have one more spare though!
Dan_K
Postby g7nbp » Sat Apr 04, 2009 3:21 pm
sorry about digging up an old thread, but thought it worth adding a comment as this is the spot most google searches point to.
I have the same issue with a brand new boarduino and ftdi ttl-232R-3v3 cable. I picked up both from the UK maker faire a couple of weeks back, but only just got round to populating the board. Ive tested on Linux, mac and PC.
The onboard ftdi chip in the cable is working as it is reported and offers a port on /dev/ttyUSB0 but when uploading avrdude times out and reports a missing programmer:
avrdude: stk500_recv(): programmer is not responding
scoping the pins shows TTL on the data lines. Linking txd to rxd (yellow to orange) and typing into the send box on the arduino serial monitor produces an echo of the sent chars, so based on the above tests I conclude the cable is fine.
Ive lifted one leg on the reset cap in case that was the issue with no change.
Im just checking the board for bad joints now, 30 years of soldering behind me, so by the law of averages I must be overdue for a dry joint by now, but with so few on the PCB it doesnt feel likely. Optically they all look good. The next test after that will be swapping the AVR to another arduino to check it progs ok in there. Currently I see the triple LED flash on reset, so have been assuming it to be OK.
I will report back later....
g7nbp
Postby g7nbp » Sat Apr 04, 2009 3:35 pm
well I cant find any board faults, but swapping the avr doesnt fix it either.
to use a popular quotation "tests have been... inconclusive" :(
I shall pour another glass of merlot and contemplate.
g7nbp
Postby g7nbp » Sat Apr 04, 2009 4:43 pm
Ok... Merlot helped a lot :)
Yes, it was the AVR. My previous checks were not thorough enough.
Its toast.
I must stop wearing nylon underpants and stroking the cat while building projects ;)
Seriously though, Im surprised. the kit was in a zerostat bag when bought, it only came out of the bag onto my equipotential mat and assembly followed normal(ish!) ESD routine... OK I wasnt wearing my wrist strap, but iron, mat and all assembly kit including the "helping hands" are equipot. This is the first one Ive smoked thru static. My real job has me handling stuff thats a) much more ESD sensitive and b) just a tad more expensive to replace. Its not usually a problem here. The Atmega series are usually all but bomb proof.
I shall chalk this one up to "one of those unexplained things"... and stop wearing nylon underpants... (the cat hides whenever Im building something now)
g7nbp
Previous
Return to Fuzebox
Users browsing this forum: No registered users and 1 guest
New Products [103]
LEDs[109]
Cables[61]
