G is for GROUND! The latest Circuit Playground is here!
Ubuntu 8.10 compiling troubles...
Moderator: adafruit
by Flecko on Sat Jan 03, 2009 11:58 pm
Greetings Fuzeboxers,
I just wanted to post a heads up to anyone that is trying to compile any of the fuzebox examples or even their own programs under Ubuntu 8.10.
I found that there is a bug in the binutils-avr package that means that the avr-size program doesn't recognize the -C option. The version of avr-size that comes with the default 8.10 supplied version of binutils-avr is outdated. If you get the newer Jaunty version of binutils-avr, there is another bug that strikes concerning the option -mmcu=atmega644.
So for now, if you're using Ubuntu(like I am) then you're out of luck for compiling programs for your Fuzebox. If anyone here knows of a workaround, I'm all ears, but I suppose I'll just have to use VirtualBox to install a VM of some other distro that ships the right versions.
Take care 'boxers!
Flecko
Re: Ubuntu 8.10 compiling troubles...
by adafruit on Sun Jan 04, 2009 2:07 am
whats the bug in the latest version that prevents coding for m644???
by Flecko on Sun Jan 04, 2009 12:04 pm
Well, as of yesterdays Jaunty binutils-avr, the error I'm seeing is that the assembler doesn't recognize the option -mmcu=atmega644
flecko@flextop:~/fuzefirmware-v2b2/hello$ make
avr-gcc -I.. -mmcu=atmega644 -Wall -gdwarf-2 -std=gnu99 -DF_CPU=28636360UL -Os -DVIDEO_MODE=1 -fsigned-char -MD -MP -MT hello.o -MF dep/hello.o.d  -c  hello.c
as: unrecognized option '-mmcu=atmega644'
make: *** [hello.o] Error 1
My download of Jaunty finished overnight, so I'm going to see if I can get anything going after I install it. I'll post back the details.
Flecko
by Flecko on Sun Jan 04, 2009 1:29 pm
Good news!
As of todays latest Jaunty updates, everything seems to be working fine, so don't panic!
It looks like just 8.10 that has the troubles. I shouldn't have gotten cocky and mixed Jaunty packages with an 8.10 install. Besides, 9.04 will be out in a few months, so I would recommend running it under Virtualbox until then just because you never know what kind of stability an alpha has.
Good luck 'boxers!
Flecko
by nitrofurano on Sun May 31, 2009 5:36 pm
as soon as having working Uzebox emulator and development tools, please help us making tarballs or binary .deb files, and share them with us! =)
nitrofurano
