Problem or missing part
- dish67
I just received my other "Adafruit Blue*White 16x2 LCD Keypad Kit for Raspberry Pi"
but when I solded the LCD on Board I noticed on board I have 18 holes and on LCD I have
16 holes ....
Do you have solution for me ..
- dish67
Re: Problem or missing part
look my picture / board + LCD
- Attachments
- image_adafruit.jpg (81.47 KiB) Viewed 701 times
- adafruit_support_bill
That is correct. The shield works with both the monochrome (Blue/White) and the RGB displays. The two extra pins are for the RGB displays.
When you install the display, it should be aligned as you have it there. Just snap off the two extra pins. The holes in the corners of the display should line up with the similar size holes in the shield.
- dish67
thank you I will try
