Breadboard Polarity Notes
- deanafruit
I built the Adjustable breadboard power supply kit - v1.0 and I noticed that the voltage output works for the half sized breadboard where the positive rail is on the outside and the negative is on the inside. This is what is shown in the instructions. However, if you use the full sized breadboard or the large solderless breadboard the voltage sense is reversed where the positive rail is on the inside and the negative the outside. You only need to flip it around but the cabling becomes much more awkward. Just a note and is should be mentioned in the instructions.
Re: Breadboard Polarity Notes
Thanks for the feedback. I'll pass it along to the folks who manage the Learning System.
