I've got a problem with Xbee and sleep mode.
I have a test setup with an Arduino Uno which reads an ultrasound sensor and sends the measured distance to an Xbee (S1) module.
On the receiver end I have another Xbee S1 connected using an FTDI cable to a raspberry pi and a terminal looking at the serial port.
I had everything working, so the measurement was sent reliably to the raspberry pi, but the setup uses too much power, so I started working on the power consumption. I want to put the Xbee to sleep most of the time, wake it up after a measurement has been taken and send out the result.
I used the SM1 mode, so I put the DTR (on the adafruit xbee kit) high to put the xbee to sleep, and low to wake it up. Measuring the used current during the cycle, the sleep/wake cycle seems to work. However, data only is received only sporadically, and I receive strange characters sometimes. If I put the Xbee in SM0 (no sleep), everything works fine again (but power consumption is too high)h.
Any ideas?
thanks in advance
Xbee sleep mode problem
Re: Xbee sleep mode problem
Try checking in the Digi Int forums for a possible solution.
Sounds like the Xbee isnt being given enough time to send a full packet. Increase the delay before sleeping the xbee again. If you are using the xbee pin to sleep/wake then this is easy in your arduino code.
- yogeshsingh
Rainz wrote:Sounds like the Xbee isnt being given enough time to send a full packet. Increase the delay before sleeping the xbee again. If you are using the xbee pin to sleep/wake then this is easy in your arduino code.
Actually i have also same problem but i seem to find out xbee usually buffer data and send it only when i put it in sleep.
Increasing the wake time doesn't seem like a good option.
I have one more problem with xbee At mode(in pin hibernate ) usually send packets but seem to missing 1 out of every 10 packets.
Sometime, I am also getting more than one packet one of which is usually the previous packet which i already got.
"Please don't mention Ask digi as it already past two days and they doen't seem to be bother about replying"
Please reply asap.
