I was hoping that there might be a step by step procedure for installing the extra python libraries - wxPython, numpy, and pylab (others if needed such as simplejson, matplotlib) - I have tried several times, twice on a Vista OS and once on XP, and I seem to get stuck at matplotlib with attribute errors. Everything else works fine I have good data using the wattcher.py script as long as I keep Graphit = False. I am looking for a push in the right direction any help will be much appreciated.
M
Tweet-a-watt graphing - with wattcher.py
Re: Tweet-a-watt graphing - with wattcher.py
there's a reason it didn't make it into the print article , it doesnt work on some machines due to python library inconsistancies and if you use the wrong python version it wont work either.
