Remove the computer: Xbee to Asus router
Xbee projects like the adapter, xbee tutorials, tweetawatt/wattcher, etc. purchased at Adafruit
Postby __ew__ » Tue Sep 15, 2009 11:57 pm
My tweet-a-watt project is up and running. I have my receiver connected to my Asus WL-500G Premium v2 router via the FTDI USB cable.
I want to solder the Xbee receiver into my router like Limor did in her blog video but I don't know which Xbee pins go to which router pins.
Could someone who has this working help me map the XBee shield pins to the router serial header pins?
Thanks in advance.
__ew__
Re: Remove the computer: Xbee to Asus router
Postby __ew__ » Thu Sep 17, 2009 1:43 pm
@adafruit Thanks for the image. I tried gleaning the mapping from your video (and failed) originally.
Ok, looking at the really hi-res version of that photo, I guessing the connections map thusly:
XBee:
  • Brown -> Gnd
  • Yellow -> Rx
  • Orange -> Tx
  • Red -> Either Cts or 3v (which?)
Asus header (I'll call pin 1 the pin closest to the 'J4' label on the asus board):
  • Brown -> Pin 2(???)
  • Yellow -> Pin 3
  • Orange -> Pin 4(???)
  • Red -> Pin 1
Can you confirm the XBee red wire for me? Seems it should go to 3v otherwise how would the XBee get power?
Also, any thoughts on the connections to the Asus header? The heat-shrink tubing makes it difficult to tell.
I'm also a little confused because the mappings on this image seem to have the CTS and RTS labels switched (Is the PCB label correct?)
Thank you,
Eric.
__ew__
Postby adafruit » Thu Sep 17, 2009 1:57 pm
power is 3V, it wouldnt make sense to try and power it from CTS eh?
the red text is correct
Postby __ew__ » Wed Sep 23, 2009 1:23 am
I now have my Asus WL-500G Premium v2 working with the xbee soldered into the serial header.
Photos:
The Asus serial header
The XBee wireless modem adapter
Pin mapping:
Asus     Color   XBee
header  (photo)  header
pin 1   green    3v
pin 2   grey     TX
pin 3   purple   RX
pin 4   blue     GND
The serial port in OpenWRT is at /dev/tts/0
The baud rate is 9600
It seems to take a minute or so after booting up for the wattcher.py script to be able to communicate with the xbee.
See also:
http://lizard43.blogspot.com/2009/03/tweet-we-using-asus-wl-520gu-and-xbee.html
OpenWrt serial pin chart for the WL500GPV2
__ew__
Postby adafruit » Wed Sep 23, 2009 9:04 am
fantastic work! and a nice clear photo :) im sure he'll will find it ultra helpful
Return to XBee products from Adafruit
Users browsing this forum: No registered users and 1 guest
New Products [102]
LEDs[109]
Cables[60]
