I am using the xbee adaptor
on a breadboard. and jumping wires.
the most extrange thing happens: if I am close to the xbee works, fi I walk away stop working.
and sometimes is vice-versa, another problem is if I lift the usb adaptor ( all the prject is on piece of wood) the xbee stop sending data.
any clue why this is happenig or how to fix it.
Xbee Adaptor Weird, Motion Problem
- Franklin97355
Re: Xbee Adaptor Weird, Motion Problem
Sounds like a loose connection somewhere. Try moving everything to a new spot on the breadboard.
- balam
thanks for the reply,
I move to a new spot, the problem persists.
- Franklin97355
Post some large clear pictures of your circuit and a schematic.
- balam
thanks for this help.
I actually soldered the tx rx pwr anb ground pins to wires.
the problem persist.
is very weird....
pic attach
is very weird....
pic attach
- balam
picture of xbee and arduino lilypad, bat, and lilypowr
- Attachments
- xbee.jpg (252.38 KiB) Viewed 1400 times
- balam
it so so weird.
I have tryed several fixes and same problem
- balam
any suggestions ?
- balam
Re: Xbee Adaptor Weird, Motion Problem -- SOLVE---
sorry, was my fault.
I totally forgot that I had the lilypad code for flex sensor, and after serverl hrs of trbloshutting and moving wires around. I just remembered that the chip had code for sensor . totally forgot about that,
originaly my lilypad had just a plain serial print.
no sensor.
I re upload the original serial print line and now works.
sorry, I had a great lesson.
"keep track of things"
thanks for your help.
no sensor.
