Hi to all,
Several days ago I bought a couple of Xbee modules XB24. they were working fine for one week or so and at a certain moment they got completly bricked .I dont know what could causes it. They both show the same "synthomps".when I connect them the to the pc via a ftdi cable the green led starts to blink rapidly but not at the normal rate of one blink per second but much more faster.I have tried hundred of times to rewrite the firmware original wit x-ctu but always with the same result; when the AT commands are going to be written I always have the same error: "the volatile memory could no be written" .
In this moment I am very disappointed with the xbee modules. I have several questions :
1 º Is there any way for the modules to be recovered.
2º Are the xbee modules so fragile that sooner or later their destiny is got bricked.( they arent cheap)?.
3ºShould they be handled in a certain way to avoid this?.
Thank you I am looking forward to your advices.
Guillermo
Xbee bricked
Re: Xbee bricked
wow you really did something strange to them! did you input any voltages higher than 3V?
- guillermo3r
Re: Xbee bricked
I dont think so but I am not very sure.I have been used them to control wirelessly two servos with two arduino. The xbee modules are attached to the arduinos with xbee shield. I cant rule out that during the manipulation of the circuits a peak of current could have damaged the xbees. So I thik that they are unrecoverable.
Guillermo
Guillermo
- richms
Re: Xbee bricked
I did something to one of mine that started doing that when I was borrowing a pair of pro ones.
I had the actual maxstream dev kit boards which had a reset button on them. By pushing that off and on while clicking write in x-ctu it eventually came back.
I had stuffed up reading Limors instructions and put wrong things in places when trying to program them to be tweetawatts.
So try soldering a button or wire to the reset pin on the xbee adaptor and toggling it while trying to write new settings...
- guillermo3r
Re: Xbee bricked
OK, I will try and post the results
Guillermo
Guillermo
- guillermo3r
Re: Xbee bricked
No luck . I followed your instructions. At the very beginning all seems to work fine because the initializing and programming modem bars progress normally but the setting AT parameters bar always stop warning an error like no AT parameters to set ,unable to write volatile memory or AT parameters out of range. Any idea.
Guillermo.
Guillermo.
Re: Xbee bricked
you could try contacting Digi...they do have a tech support team
