Tweet-a-watt power issue?
- rbcameron1
Re: Tweet-a-watt power issue?
I have the P4400.1 revision. I promised my boss I can get this to work only to realize that what you show online isn't even close to what I cracked open. Any updates would be absolutely helpful!
- Franklin97355
Post photos. This is an old project and may no longer work with the new Kill-a-Watts. You will need to find the ADC pins and hope there is enough extra power available to power the added circuitry
- rbcameron1
I'm hoping I can use these, or I'm really up a creek with no paddle...
I'm no electrical engineer, but if everything is just rearranged, I'm good at soldering.
My guess is that the connection points are behind the LCD screen.
- rbcameron1
One more image up close....
- Franklin97355
What are the part numbers of the two chips in the last photo?
- rbcameron1
P/N: 6522022W02 rA for the board itself for the LCD
P/N: 6522022W01 rA for the board for the plug in part
the rectangular circuit chip has a TI logo on them and say: 36P1MKAG3 and LM2902 on the second line
and the square chip says: FT24C02A (I can't tell if it says CQ2a or Co2A) and then the second line is 45ROFD
- Franklin97355
The LM2902 is the chip you need to connect to. Follow this thread and the instructions here https://learn.adafruit.com/tweet-a-watt ... ransmitter
- rbcameron1
What did people do with the fact the LCD still had to fit flush back on the face? The LCD fits over the chip I'm soldering to when I go to reassemble. I guess I'll have to get creative...?
- Franklin97355
This picture is the newer style. I would get some of the flexible silicone wire in 30ga and use that.
- 2015-01-18_19h34_29.png (254.45 KiB) Viewed 629 times
