XBee stops listening after +++
Xbee projects like the adapter, xbee tutorials, tweetawatt/wattcher, etc. purchased at Adafruit
Postby joe61 » Sat Apr 16, 2011 11:27 am
I'm trying to get a couple of the Series 2 modules working with the XBee adapter. I'm guessing the board was soldered correctly because X-CTU was able to upgrade the firmware, and I can connect to it with a serial connection from my Mac and Linux box ok.
I start off by typing +++ and get the expected "OK" back, but then nothing. When I type "ATID" no response. Clues would be welcome.
I did some searching but didn't see another thread that addressed this. Sorry if I missed it.
Joe
joe61
Re: XBee stops listening after +++
Postby franklin97355 » Sat Apr 16, 2011 1:03 pm
Are you sure the series 2 modules work with the adapter? I don't think adafruit supports series 2
franklin97355
Postby joe61 » Sat Apr 16, 2011 1:41 pm
I saw a thread here that said they work:
viewtopic.php?f=40&t=19595
Joe
joe61
Postby franklin97355 » Sat Apr 16, 2011 2:43 pm
Have you updated the firmware and tested them with X-CTU?
franklin97355
Postby joe61 » Sat Apr 16, 2011 2:47 pm
Yes, I've updated the firmware with X-CTU. That's what made me think the board was ok, because the update appeared to go well.
However, I just tried swapping adapter boards, and the XBee that wasn't working now works, so I messed up something when I was putting it together. My apologies.
Joe
joe61
Postby JChristensen » Sat Apr 16, 2011 2:48 pm
How long are you waiting between getting the OK and typing the next command? Command mode times out by default after 10 seconds. The AFI adapter works fine with my S2 modules.
JChristensen
Postby joe61 » Sat Apr 16, 2011 3:32 pm
JChristensen wrote:How long are you waiting between getting the OK and typing the next command? Command mode times out by default after 10 seconds. The AFI adapter works fine with my S2 modules.
I'm aware of the timeout, but it turns out that's not the problem. I have two XBees and two of the Adafruit adapters. One works as expected, the other one wasn't. I apparently used too much solder when putting in the headers that the XBee plugs into. I used some solder wick to pull out excess solder and it's working fine now.
So, my mistake. I was hoping that was it because this looks to be the best XBee adapter I've seen. Anyway, sorry for the bother.
Joe
joe61
Postby franklin97355 » Sun Apr 17, 2011 12:49 pm
No bother, it's always good when someone can learn from mistakes and it will help others in the same situation. As you progress you will get better.
franklin97355
Return to XBee products from Adafruit
Users browsing this forum: etti and 2 guests
New Products [103]
LEDs[109]
Cables[61]
