Remote Volatge Monitoring
XBee projects like the adapter, xBee tutorials, tweetawatt/wattcher, etc. from Adafruit
WD8MBE
Post by WD8MBE »
Hi, name is Tom and I am new to the forum.
I have a solar and wind setup with everything located in my garage, including the storage batteries. I want to use 2 Xbees to monitor the voltages and send it to my PC located in the house.
Also, I would like to track these voltages over a given period of time. Can anyone help me on how to configure and wire the Xbees to monitor 10-15 VDC and 0-35 amps?
Thanks in advance,
Tom
Franklin97355
Re: Remote Volatge Monitoring
Post by Franklin97355 »
Have you looked at the Tweet-A-Watt project? It should give you some ideas for starters.
WD8MBE
Post by WD8MBE »
Hi Franklin,
Thanks for your response. I now have XBee's setup using the Kill-A-Watt software. And I am displaying using EnergyLogger.
Now the voltage sensor input (AD0/D100) what type and value of voltage is it expecting? DC Voltage, Micro Volts, AC?
Just for experimentation, could I hook a 1.5v AA battery to Grd and AD0 and get a reading. By the way, I am using Parallax 5v/3.3v adapter board.
Thanks,
Tom
Post by adafruit »
tweetawatt must be calibrated. thats why there is a calibration step. follow the tutorial for calibration and voltage checking
miketranch
Post by miketranch »
I took a different approach in my project. I decided to use Raspberry Pi for a base station, and have several remote transmitters. Each transmitter is responsible for its own calibration. They send human readable ASCII info and the R-Pi datalogs it all to the SD card. (No waveform plots, but that's OK I have oscopes for that.) I used a Moteino (arduino compatible, with RFM12B), and the calibration factors are part of the sketch. More info at my blog:
http://forums.adafruit.com/viewtopic.ph ... 41#p242641
and links there to my youtube channel
Return to “XBee products (discontinued)”
