I want to combine the Tweet-a-Watt kit with the Data Logger kit. Instead of tweeting the output of the Kill-a-Watt I want to record it with the Data Logger.
My problem is I don't get a voltage out of the Kill-a-Watt that varies with the current of the device plugged into it. I want the Data Logger to read that voltage.
The Tweet-a-Watt instructions say:
Connect Kill-a-watt LM2902N chip pin 1 (current sensor ) to the XBee AD4
Connect Kill-a-watt LM2902N chip pin 14 (voltage sensor) to the XBee AD0
I want to connect the pins 1 and 14 to the data logger analog read inputs.
The voltage on pin1 (compared to the ground on pin 11) should vary when I plug different appliances into the Kill-a-Watt. It doesn't. It should reflect the different current draw. All I get is 2.344V on my volt meter no matter what I plug in, and no matter if the appliance is turned on or off.
The voltage on pin 14 should remain constant since the voltage is always 120V. It does. it reads 2.334V and is unchanging. But how can I change the voltage to see if pin 14 is varying with the line voltage?
In summary:
Why does the voltage on pin 1 not change with the appliance current?
How can I change the line voltage to see if the pin 14 voltage changes?
Any suggestions?
Paul Herzmark
Berkeley, CA
