Modifying relay control with xbee
by ddn on Tue Jun 05, 2012 5:05 pm
A couple years ago I built the relay control xbee setup described here http://www.adafruit.com/blog/2009/04/21 ... ol-relays/
Now I'd like to modify it so that I can toggle the state of the remote relay via USB/serial instead of requiring a hardware button press (which I was using a parallel port for before).
But I've banged my head for hours and can't figure out how to either send a remote command, or to get the state of the local USB xbee to pass to the remote.
I'd appreciate any guidance.
ddn
Re: Modifying relay control with xbee
by adafruit_support_rick on Tue Jun 05, 2012 7:11 pm
can you post your code?
by ddn on Tue Jun 05, 2012 8:04 pm
driverblock wrote:can you post your code?
I've just been using X-CTU to send API command requests. ie:
7E 00 10 17 01 00 00 00 00 00 00 FF FF FF FE 00 44 32 04 72
ddn
by adafruit_support_rick on Tue Jun 05, 2012 11:23 pm
Oh, OK. So you still want to control the thing from Windows, not a microcontroller.
by ddn on Tue Jun 05, 2012 11:26 pm
Actually, from a Linux machine. But I reasoned that once I figured out how they needed to be configured and what the right commands to send were, I could use Python or C to accomplish the same thing.
ddn
by adafruit_support_bill on Wed Jun 06, 2012 6:12 am
Rob Faludi has a Processing API for XBees. You might want to check out his book too.
