Memorial day is 05/25/2015 – Orders will ship out on May 26th. There will not be any deliveries or shipping on Monday. Any order placed after 11am ET on Friday May 22nd will not start to ship out until Tuesday May 26th.
3.3V Xbee Adapter Pins
by seancron on Sat Aug 04, 2012 11:22 pm
I have an Adafruit Xbee adapter that I'm trying to use to update a 3.3V LCD from my computer.
I'm planning on powering the Xbee and LCD with 4 NiMH AA batteries. I was just about to wire up a circuit to regulate the battery voltage, when I noticed the 3V pins on the Xbee adapter.
Can I use those pins (#1 and #10) to power my 3.3V LCD, if I connect the battery pack directly to the 5V and ground pins on the Xbee adapter? Or should I still make a circuit to regulate the voltage for both?
seancron
Re: 3.3V Xbee Adapter Pins
by adafruit_support_bill on Sun Aug 05, 2012 6:01 am
The schematic is here: http://www.ladyada.net/images/xbee/xbee11sch.png
The 5v pins are fed to a 3.3v regulator which powers the level shifter and is also available on pins 1 & 10.
You should be fine powering it with the 4.8v from your NiMH cells.
