xbee antenna
xbee antenna
by cfloryiv on Mon Sep 03, 2012 3:37 am
can the xbee antenna bend 90 degrees? My xbee shield is below a motor shield. I would like to upgrade from the pcb antenna to the wire antenna to get better reception.
cfloryiv
Re: xbee antenna
by adafruit_support_bill on Mon Sep 03, 2012 6:37 am
The wire antenna will bend, but close proximity to the PCB above will not result in optimal performance. You might want to consider one of the external antenna options from Digi: http://www.digi.com/support/kbase/kbaseresultdetl?id=2167
