USB adapter and Pi
USB adapter and Pi
by thelandofthedave on Fri Nov 16, 2012 10:16 am
Will the USB XBee adapter play nice with a raspberry pi? The rover im building sure hopes it will :)
thelandofthedave
Re: USB adapter and Pi
by adafruit on Fri Nov 16, 2012 9:40 pm
Not sure if FTDI chips are supported on the Pi, unfortunately :(
by thelandofthedave on Sat Nov 17, 2012 11:33 am
Bummer. Is it safe to assume that i oculd use the cobbler breakout board and connect up the xbee via the cobber breakout board?
thelandofthedave
by adafruit on Sat Nov 17, 2012 2:34 pm
that's right! check out our NFC + Pi breakout tutorial for how to disable the console, then you can use the 3v ttl serial port
by thelandofthedave on Sat Nov 17, 2012 7:19 pm
Awesome!!! Thanks, order to be placed sometime in the very near future.
thelandofthedave
