xBee and humidity sensor
by dsbach on Fri Nov 23, 2012 12:18 pm
I want to use the Honeywell HIH-4030 (analog) humidity sensor with an xBee. :)
xBee requires 3.3Vdc and the sensor 5Vdc. :?
I will be supplying power via a wall wart (most likely 5Vdc).
What products do you have to allow each device to have its proper voltage? :?:
(If this post is duplicated, I apologize, but I can't find my first attempt.)
dsbach
