Opening port seems to Kill Xbee
by countzer0 on Tue Jan 22, 2013 11:07 am
I have a FTDI cable and a Xbee adapter. I had this working(with a arduino/xbee on the other end) a couple of months ago and formatted my windows 7 system in the meantime so I am think the problem is related to the port/driver.
When the device is plugged in, the green led blinks at a regular rate(I think this is correct). When I open the comm port with either hyperterm or coolterm the LED goes off and sending +++ does not return an OK. At one point in my experimentation over the years, I thought there was something that needed to be done(OS-wise) to the comm port but I can't seem to find it.
Any ideas would be great.
countzer0
Re: Opening port seems to Kill Xbee
by countzer0 on Tue Jan 22, 2013 12:29 pm
I have tried it on a second Win7 PC and it is working correctly. The blinking led does not blink when connected and the red blinks when receiving data.
countzer0
by adafruit_support_bill on Tue Jan 22, 2013 12:59 pm
Make sure your com port is configured for the correct baud rate & no flow control: http://www.ladyada.net/make/xbee/configure.html
It might be easiest to compare the configuration with the machine that works and see what is different.
