Hi, I cracked the antenna off of my "XBee Pro Module - Series 1 - 60mW with Wire Antenna". Are the antennas possible to replace? Does Adafruit sell them?
Thanks much!
Replacement for cracked xbee pro wire antenna?
- Franklin97355
Re: Replacement for cracked xbee pro wire antenna?
If you didn't break the pad it is soldered to the antenna is just a wire and can be replaced with good soldering skills.
- adafruit_support_bill
We do not stock replacements for these. If Franklin's suggestion does not work for you, you could check over at the Digi forums to see if they have a remedy. http://forums.digi.com/support/forum/index
