GPS Project Transmit NMEA data to pc
Hi, we have suceesfully configure the xbee we have just brought and tested it with the sample aurdrino sketches(communication) physical pixal and everythings is working all right. Now the problem is how do we go about transmitting the NMEA data received from the adafruit GPS to a computer through Xbee? Is there a program which must be written to transmit the data receive from the Gps to the xbee? Please enlighten us
- Franklin97355
Re: GPS Project Transmit NMEA data to pc
If you hook up and configure the xbee it will send serial data to another xbee. The xbee on the PC can be connected using a USB breakout board and then you run a program that reads the serial port created by the USB device and do whatever you need to do with that. Take a look at some of the xbee examples in the learning section of Adafruit.
I have done a little research on a program that reads the serial port created by the usb device but to no avail. What u mean is when i connect my gps to the xbee shield, it should automatically start sending nmea data over to my other xbee connected to a computer?
What format is the xbee data send to the computer in?
- Franklin97355
From the USB xbee adapter it is straight serial data, plain text. NMEA data http://aprs.gids.nl/nmea/
Haha i got it sending already but the next step is how do we go about saving the data received onto the computer for example in a notepad?
- Attachments
- data received.PNG (49.25 KiB) Viewed 1262 times
After doing more research am i right to say that in order for me to store the data in the xctu Terminal tab, i must write a program to read the serial port(the port which my xbee usb explorer is connect) of my computer?
You could use any of the many terminal programs available for Windows. Hyperterm, RealTerm & TeraTerm are a few.
I like TeraTerm which is a free download from:
http://ttssh2.sourceforge.jp/index.html.en
If you need to GPS data in another format and/or do calculations on the data (like extracting a heading or speed) then you need to write a program to run on your PC. I recommend using Python 2.7 since this works on many platforms, Windows & Linux including the R-Pi, so there are many examples.
