XBEE Adapter Kit 3.87v
XBee projects like the adapter, xBee tutorials, tweetawatt/wattcher, etc. from Adafruit
ReidCarlberg
Post by ReidCarlberg »
Hi, just testing my adapter and it's a little funky. Not communicating with other XBees, red light on just a little, green light not at all. Voltage between G and 3v is measuring 3.87 (no XBEE installed). Any advice? Thanks!
Photo on 11-1-13 at 4.23 PM.jpg (104.88 KiB) Viewed 718 times
Photo on 11-1-13 at 4.22 PM.jpg (109.39 KiB) Viewed 718 times
Re: XBEE Adapter Kit 3.87v
The photo is not quite clear, but the solder on the XBee headers looks a little suspicious. If you could take one at a bit of an angle and in better focus, I could see the profile of the joint better.
The 3v. pin should measure 3.3v. Check to make sure that your meter has fresh batteries. Some meters read high when the batteries start to fade.
Return to “XBee products (discontinued)”
