Hi ,
Another UK Xbee newbie here. I am using V1.1 adapter kits with the 869.5Mhz Pro xbee modules. These can take 500mA or more when set to highest power. All works well at low power setting but unsurprisingly doesn't work on high power. Is there a well known hack out there to handle this? For example can I replace the standard voltage regulator with something more powerful ? ( it doesn't have to remain within the adapter card foot print). Or could I use an external 3.3V regulator and connect direct into the xbee module bypassing the standard on board regulator? I there a schematic of the adapter card available so maybe I could work it out myself?
I am only using Tx and Rx plus power connections on the xbee so I don't have to worry about handshake lines. I/O connections etc. Any assistance much appreciated.
Baggy2
Hi power xbee on v1.1 adapter kit
Re: Hi power xbee on v1.1 adapter kit
Don't know of anyone who has done this. But you could replace the existing regulator, or bypass it by feeding 3.3v to the adaptor via the VCC pin on the header.
Schematics are available here: http://www.ladyada.net/make/xbee/download.html
For high current applications like this, linear regulators can be pretty inefficient. You may want to consider a buck converter instead: http://www.adafruit.com/products/1066
- baggy2
Thanks for the quick reply - that does give me something to work with. If any other readers are around with " been there - done that" experience it would be great to hear from you too.
Cheers
Baggy 2
Cheers
Baggy 2
