Simple sending of NEMA GPS
XBee projects like the adapter, xBee tutorials, tweetawatt/wattcher, etc. from Adafruit
brizey
Post by brizey »
Is there a simple way to directly hookup any XBEE module to a GPS module that adafruit sells and send it without a arduino or other device? I just want to recieve the NEMA Sentences on a PC.
Franklin97355
Re: Simple sending of NEMA GPS
Post by Franklin97355 »
I would try hooking the TX and RX of the GPS to the RX and TX of the xbee adapter. Be aware the xbee module itself is not 5v tolerant.
1chicagodave
Post by 1chicagodave »
The GPS module itself is a 3.3V device. It appears that the breakout has a direct connection from TX to the header.
GPS TX
GPS TX
brizey
Post by brizey »
Ok, Thanks guess I need to get some type of parts list so I can figure out what I need.
1chicagodave
Cool. Please post results when you get it working!
*Just remember, if you change any settings in the GPS module (baud rate, update rate, etc...) you will need to keep the backup battery installed in order to keep those changes saved when the GPS is not powered. Otherwise it resets to factory default settings.
Return to “XBee products (discontinued)”
