XBee starter Kit
XBee projects like the adapter, xBee tutorials, tweetawatt/wattcher, etc. from Adafruit
lueis
XBee starter Kit
Post by lueis »
hi,
I want to use XBee for my wireless measurement project (angle).
Is it possible to set this code on XBee without Arduino? If I need Arduino, can i use the XBee as a standalone-system (transmitter and reciever) without arduino in my final system or will the Code be deleted after i pulled it out of the Arduino?
Is there a good starter kit you can recommend for S2? What do i need to start? Is there anything else you can recommend?
lueis
Franklin97355
Re: XBee starter Kit
Post by Franklin97355 »
The Adafruit adapters will allow you to connect to the xbees with most devices including (with the right cable) a computer. Check with Digi as I think they now make an xbee with a built in processor which sounds like what you are looking for.
Return to “XBee products (discontinued)”
