Product ID: 247
Is it ok to power the xbee via USB with this adapter and power it through the Vdd pin at the same time to ensure that the xbee is always on?
XBee USB Adapter
- Franklin97355
Re: XBee USB Adapter
According to the schematic here http://www.parallax.com/sites/default/f ... atic_B.pdf they both feed the regulator but the input voltage for VDD is 5V so be careful and use a good, regulated supply.
Thanks! I see that they don't give a max Vin to the regulator however the fact that that they say Vdd is 5v and Vusb is 5v volts that you can connect them at the same if you are careful as you said.
