xBee connection failed with xtcu
XBee projects like the adapter, xBee tutorials, tweetawatt/wattcher, etc. from Adafruit
mjpcarbon
Post by mjpcarbon »
For some reason in which I hope you can enlighten I am having a heck of a time getting xtcu to read or write to the XBee, worked fine once or twice now nonstop failed attempts.
The xbee works fine in the project
Franklin97355
Re: xBee connection failed with xtcu
Post by Franklin97355 »
How are you connecting to the xbee to communicate?
mjpcarbon
Post by mjpcarbon »
Your adapter and ftdi cable
Usually takes several tries , is this normal. Sometimes on the first try other times it takes 5-6 attempts
Franklin97355
Could you post clear pictures of your board, any soldering you did ?
Return to “XBee products (discontinued)”
