Couple questions,
Can I transmit 10Dof data via xBees ?
If so what should the xBee TX and RX be set to so the info is properly transferred
10DOF via xBees ?
Re: 10DOF via xBees ?
You would need a processor to read the data from the 10DOF and relay it through the XBee.
- mjpcarbon
Ahhh, I had hoped to have an UNO on the RX side
So I need UNOs on both TX and RX sides ?
Some of the higher-end XBee modules are programmable via their SDK, so you might be able to do it without an extra processor. But that is not something we have experience with here. You might check over at the Digi forums for advice on that.
- mjpcarbon
Ahhh buggah thats too bad.
OK so a few more questions if this is still a viable plan
- mjpcarbon
Bill a bit more info please.
So am I correct in understanding if I have the 10dof into a UNO then I can transmit the signal via xBee ?
The TX side would have the following components 10dof,UNO,XBee......?
How about on the RX side ?
That depends. What do you need to do with the data on the Rx side?
- mjpcarbon
Well I want to control two servos Yaw and either Pitch or Roll
I have it working pretty well, a little jittery, on the bench now would really like to do it wirelessly with all the addictive stuff you have
Then you would need a microcontroller on the Rx side too. It would read from the XBee and control the servos.
- mjpcarbon
Bill you are very helpful now I need more guidance
I have my sketch and happy with it so far.
Can I use trinkets in place of the UNOs ?
I am a bit at a loss as to how I send the data from the TX Uno into the xBee and then of course how to transfer the data from the RX xBee into the RX Uno
- Franklin97355
How do you have things connected on the test circuit and what code are you running? That will help in answering your questions.
A Pro Trinket should easily handle it. You might be able to squeeze it into a regular Trinket. It would probably require a bit of library hacking to switch tinyWire-M for the regular wire library to talk to the IMU.
Talking to the XBees is just like talking to the serial port. Connect Rx->Tx and Tx->Rx. If you have the XBes in AT mode, it will behave just like a wireless serial port at both ends.
- mjpcarbon
Pins 2 and 3 in AT mode will transfer the data.
How about on the UNO TX out to Xbee ?
Just connect the UNO Tx to the XBee Rx and UNO Rx to XBee Tx. Then read and write to it like any other serial port.
https://learn.adafruit.com/xbee-radios/point2point
- mjpcarbon
Will do and report back
thank you
thank you
