I'm using XTCU and two XBEE radios connected to two separate USB ports on my PC to try and get tx and rx fun going.
It appears that one XBEE is transmitting, but no receive on the other end.
Hmmmmm.....
I should mention that I'm using a Spark Fun break out board for one hookup and the adafruit dock/USB board for the other.
Ken
XBEE 1 isnt talking to XBEE2
Re: XBEE 1 isnt talking to XBEE2
Does it make a difference if you swap the 2 XBees?
- kennymac64
Nope, tried that...
- Franklin97355
Which version xbees and have you configured them at all?
- kennymac64
Firmware version: 22A7
Config changes: Changed baud rate from 9600 to 19200 and then back to 9600
I have confirmed that both are set to 9600.
- Franklin97355
Are these both series1 xbees? If they are series1 then follow these instructions to set them to communicate.
- Franklin97355
You need to set those up to communicate. They do not work "out of the box" There is some good info here http://www.faludi.com/ and on Google
- kennymac64
cool, thanks!
