XBee Adapter voltage tolerance question
- dsetin19
How much voltage can be applied to the 5v pin (e.g., could a 9v battery be used for the power supply)?
- Franklin97355
Re: XBee Adapter voltage tolerance question
6V is the maximum input voltage for the regulator.
- iasonas
What is the total voltage range that can be used at the 5V input pin? Is it defined by the regulator? Where could I find this information? Thank you!
