XBee Adapter voltage tolerance question
XBee projects like the adapter, xBee tutorials, tweetawatt/wattcher, etc. from Adafruit
dsetin19
Post by dsetin19 »
How much voltage can be applied to the 5v pin (e.g., could a 9v battery be used for the power supply)?
Franklin97355
Re: XBee Adapter voltage tolerance question
Post by Franklin97355 »
6V is the maximum input voltage for the regulator.
iasonas
Post by iasonas »
What is the total voltage range that can be used at the 5V input pin? Is it defined by the regulator? Where could I find this information? Thank you!
Return to “XBee products (discontinued)”
