XBEE ADAPTER KIT
XBee projects like the adapter, xBee tutorials, tweetawatt/wattcher, etc. from Adafruit
Re: XBEE ADAPTER KIT
That will depend on the delivery service you selected at checkout and how long it takes to clear customs inspection in your country. We don't have any control over that part of the process, so we can't give an accurate estimate.
Franklin97355
Post by Franklin97355 »
I live in Greece, how long does it take to arrive? That depends on the delivery service and their workload Adafruit usually processes the order in less than one day.
giorgio_new
Post by giorgio_new »
I bought this
https://www.adafruit.com/product/247
Which X-CTU should I download from here:
http://www.digi.com/support/supporttype?type=drivers
It has many drivers!!!!
giorgio_new
Ok I found it, but for some reason I cannot download the .exe. It seems tha Digi's site has a problem. Is there any other site I can download it?
I am not able to access the Digi download site either at this time. They are probably experiencing some temporary difficulties. Please try again later.
giorgio_new
I want to connect this product
https://learn.adafruit.com/xbee-radios/
to a PIC microcontroller to transfer data through it to another Xbee.
Because I see there are many pins on your Xbee adapter, which pins should I use for Tx,Rx with the PIC?
Also I assume for supply I use the 5 Volt pin and the ground only? Right?
I am not familiar with the PIC, but in general for serial communication you connect:
Rx->Tx
Tx->Rx
If the PIC is a 5v processor, you can power with 5v and GND.
If it is a 3.3v processor, you should power with 3.3v and GND so that the signal levels are compatible.
giorgio_new
adafruit_support_bill wrote:I am not familiar with the PIC, but in general for serial communication you connect:
Rx->Tx
Tx->Rx
PIC is 5 volt.
So the only pins I use from this
is 5 Volt and gnd for supply. And the Tx,Rx for communication with the microcontroller?
That is correct GND, 5v, Tx and Rx is enough.
Return to “XBee products (discontinued)”
