Trouble moving XBee from Uno to Trinket
XBee projects like the adapter, xBee tutorials, tweetawatt/wattcher, etc. from Adafruit
forger
Post by forger »
Our circuit is a fsr that generates a character and sends it via xbee to the other board and that triggers a LED and haptic motor on another Uno. We had full functionality on the Unos and when we moved to the Trinket(not Pro) it's as though the XBee is reading it's own serial because the affects are happening on the sending board, not the receiving.
On some finals week ish.
We've stripped all of the functions out of the code below and it still acts as though the character is not leaving the sending board.
#include <SoftwareSerial.h>
SoftwareSerial XBee(0, 1); // RX, TX
int fsrAnalogPin = 2;
void setup()
    XBee.begin(9600);
  pinMode(1, OUTPUT);
  digitalWrite(1, LOW);
  if (analogRead(fsrAnalogPin) > 450) {
    XBee.write('a');
  if (XBee.available()) {
    char c = XBee.read();
    if (c = 'a'){
      digitalWrite(1, HIGH);
Last edited by adafruit_support_bill on Mon Apr 27, 2015 7:12 pm, edited 1 time in total.
Reason: please use the </> button when submitting code. press </>, then paste your code between the [code] [/code] tags.
adafruit_support_rick
Re: Trouble moving XBee from Uno to Trinket
You need a double '==' on this statement:
    if (c = 'a'){
forger
Post by forger »
Very good, thanks for your help. We now have full functionality!
Cool.
Pro tip: Get in the habit of putting the constant on the left hand side of the conditional. That way the compiler will complain if you forget and use an single '=' instead of a double '=='
Like this:
    if ('a' = c){   //compiler will complain about this
forger
Post by forger »
Hey thanks for the help!
Return to “XBee products (discontinued)”
