Xbee s2 zb VREF 1.2 voltage divider
XBee projects like the adapter, xBee tutorials, tweetawatt/wattcher, etc. from Adafruit
ilparola
Post by ilparola »
Hi guys, i found out that VREF in xbee s2 zb is fixed at 1.2v. (and i think this is insane).
In order to work with all the most common sensor out there that runs at 3.3 or 5 volt, i need to use a voltage divide.
Could you guys suggest me which ohm value should i use for not messing with the internal resistance of the xbee?
Thanks a lot.
If there is an alternative way too i'd like to know, because maybe i'm totally wrong :)
Andrea.
adafruit_support_rick
Re: Xbee s2 zb VREF 1.2 voltage divider
Post by adafruit_support_rick »
For 5V -> 1.2V, use an 8K and a 2.7K resistor
For 3.3V -> 1.2V use a 4.7K and a 2.7K
The formula is Vout = Vin*R2/(R1+R2), where R2 is between Vout and GND. and R1 is between Vin and Vout
Return to “XBee products (discontinued)”
