I have spent the last week trying to get my two Xbee's to preform a simple action. Xbee #1 is a transmitter with a button attached to DIO0 pin. Xbee #2 is the reciver with an LED attached to DIO0 pin. When I press the button, the LED should light up. But it doesn't. Simple tutorial. But it does not work at all for me.
I have been though 20+ tutorials, read the manual, setup both Xbee's in various configurations, including but not limited to complete factory defaults with no luck at all. Including the one from Digi ( http://examples.digi.com/lights-motors- ... th-an-led/ and http://examples.digi.com/sensors/802-15 ... -a-button/ )
Both Xbee's are on the same channel (3332), and will respond (by way of onboard tx/rx leds on sheilds) that they get serial between each other. I have even had some succes when the button is pressed, the RSSI light comes on on the Receiver Xbee. Both units are a Series 1 Xbee.
One is attached to a Sparkfun usb shield (https://www.sparkfun.com/products/retired/8687) and the other is powered on a SparkFun Xbee arduino sheild (https://www.sparkfun.com/products/12847) The arduino is doing nothing other than powering the Xbee sheild. The attached LED is on a bread board.
I have it wired just like these attached photos. http://i.imgur.com/6qkdmBA.jpg http://i.imgur.com/wKDCKj7.jpg. (other than the reciever with LED is powered via an arduino)
To answer all the silly questions,
-Yes I have updated the firmware
- Yes the Trasmitter Xbee DIO0 pin is set to (3) Digital In
- Yes the Reciever Xbee DIO0 pin is set to (4) Digital out LOW
- Yes they are both on ATID 3332
- Yes I have tried setting ATIU (I/O Output Enable) to both Enabled and Disable on both, in all 4 ways, and no change
- Yes I have tried setting ATIC DIO Change Detect to 1 on both.
- Yes I have tried changing ATDL and ATMY Destination Address Low and 16-Bit Source Address to the default 0, and to separate values in their respective slots. .
- Yes I have set ATIA I/O Input Address to both the default FFFFFFFFFFFF and to the Transmitter Xbee's address. (0x1234)
- Yes I understand that the numbers above need to be in decimal form of hex. So my Transmitter Xbee address is 0x1234 or 4660
- Yes I have googled, bing'ed, youtube'd and yahoo'ed for answers. All the tutorials I get have slightly different configurations, or did not include the configuration settings. And or they were on the older XCTU software (Gray Windows 95 like format) And I am using the newer 6.2.0 version.
- Yes I have the older version of XCTU (version 5.2.8.6) and followed along with tutorials with no luck.
- Yes I have tried changing the two xbee's so that the Transmitter xbee is the receiver, and the receiver is the transmitting one
- Yes the Xbee Receiver has enough power to power the LED. I have set the DIO0 pin to Digital Out High, and the LED will light.
- and Yes, the LED is in the correct direction for signal flow.
- Yes I have tried with other DIO pins. In fact I have LEDs on DIO pins 0 thru 4, all set to different settings for purpose of testing.
- Yes, when I send random text via the command prompt on the Transmitter Xbee, I will see the Dout Light flicker for each character typed.
- When ATIC DIO Change Detect is set to 1. When I push or release the button, I will see the RSSI LED light up on the Recieiving Xbee for 4 seconds-ish
- When I push the reset button on the Recieving Xbee, The RSSI LED will light up for a few seconds and I will get initialization done. on the Tranmistter Xbee
What is it that I am doing wrong? Why am I unable to get this simple action to work?
- a very frustrated tinkerer
They are both Series 1 Xbee's (XBee 802.15.4)
Xbee's will not turn on LED from other Xbee
- Franklin97355
Re: Xbee's will not turn on LED from other Xbee
This is the only thing I can think of to give you https://learn.adafruit.com/xbee-radios/reference You might try the Digi forums for better answers.
- jerry7580
I did not see where you set the sample rate (IR). I am thinking that you probably must do this setting. I also had major challenges in getting much of this to work, so much that I almost consider myself an expert at this time, except for the fact that I have forgotten much of it. See http://knowledge.digi.com/articles/Know ... ne-Passing for additional details. If you follow this example, I think it will work for you.
