I am using the following hardware/software
XSTICK: XU-Z11 (network coordinator)
XBEE RF Module: XB24CZ7RIS-004 (desired end device)
XCTU Version 6.3.0
I have my coordinator connected to a USB port on my computer and I have configured it with the following:
Product Family: XB24-ZB
Function Set: ZigBee Coordinator API
Firmware version: 21A7
ID PAN ID: 0
SC Scan Channels: 7FFE
When my end device system starts up, my uC (XMC1300) sends a network reset to the end device. The associate LED is solid for 2 seconds, flickers out for a brief moment, then solid for 2 seconds, then flashes 5 times at a rate of about twice per second, then repeats that sequence over again. My problem is that part of this sequence seems to indicate that the module is switching between being connected to the network the coordinator has established by blinking 5 times at a rate of twice per second but then, when the LED goes solid, seems to indicate that there is no connection. What do you make of this?
Unable to confirm connection between coordinator and end dev
- stevec1234
- Franklin97355
Re: Unable to confirm connection between coordinator and end
steve, feel free to post here but I think you will get better answers to technical problems on the Digi forums.
