Snap a picture of your ADAFRUIT clock and post it here!
Tick Tock Clock Kits
Re: Snap a picture of your ADAFRUIT clock and post it here!
Postby spaulmac » Sun Jun 05, 2011 1:56 pm
Thank you, Ladyada, for a lovely little kit. It's been far too long since I've had the soldering iron in my hand.
spaulmac
Postby brianez21 » Mon Jul 04, 2011 9:49 pm
Here are two pictures of my ice tube clock! You may use them however you would like.
pic 1
pic 2
Enjoy!
brianez21
Postby wb4kxs » Mon Jul 25, 2011 12:25 pm
Ice Tube Clock with GPS.
It works great! Amazing GPS sensitivity, even indoors.
I had to put some white plastic tape over the GPS's LED
to keep it from being too bright.
Ice Tube Clock copy.jpg (78.44 KiB) Viewed 3200 times
GPS copy.jpg (31.01 KiB) Viewed 3200 times
wb4kxs
Postby ib123 » Mon Aug 15, 2011 3:31 pm
My clock:
ib123
Postby bretm » Sat Aug 20, 2011 6:54 pm
It's alive! I tried using HDR for the first time, to get a good brightness balance between the digits and the rest of the clock. The focus was too close to the front, though.
bretm
Postby colonwq » Tue Sep 20, 2011 3:13 pm
I assembled my monochron last night. I was doing good until I installed the wrong resistor for R1. I used the R2 by accident. I compounded this by removing R7 by accident. Needless to say the first 45 minutes of assembly was a bit slow. Everything proceeded without a problem. The board went 'ping' as it should, the LED turned red as it should and LCD displayed Dali time as it should. Overall, this was a great project.
colonwq
Postby 3d0g » Sun Oct 09, 2011 6:55 am
I made a simple mod adding a mode to display Posix time in hex.
What time is 4e90d1fd? :D
3d0g
Postby odometer » Sun Oct 09, 2011 12:31 pm
3d0g wrote:I made a simple mod adding a mode to display Posix time in hex.
From the JavaScript Scratchpad in Firefox 6.0.2:
* This is a JavaScript Scratchpad.
* Enter some JavaScript, then Right Click or choose from the Execute Menu:
* 1. Run to evaluate the selected text,
* 2. Inspect to bring up an Object Inspector on the result, or,
* 3. Display to insert the result in a comment after the selection.
new Date(1000*0x4e90d1fd)
Sat Oct 08 2011 18:43:09 GMT-0400 (Eastern Daylight Time)
Does that seem about right?
odometer
Postby 3d0g » Mon Oct 10, 2011 6:28 am
odometer wrote:Sat Oct 08 2011 18:43:09 GMT-0400 (Eastern Daylight Time)
Yup!
3d0g
Postby rys » Thu Nov 03, 2011 5:21 pm
Assembled this one in a hurry, thinking about building another one with GPS as a gift...
rys
Postby box » Tue Dec 13, 2011 12:28 pm
It's been a while since I ordered this kit, but now finally.. after a few hours with the soldering iron is now another Ice Tube Clock born, this time in Sweden! Up 'n running on the first try! 8)
I must also say that the instructions were absolutely perfect to assemble the clock! Kudos to you @ Adafruit!
box
Postby keithK5WX » Sat Dec 17, 2011 10:54 am
Beautiful clock!
I can't believe the level of detail that went into this kit. The instructions and photographs were perfect for constructing the kit.
Fun to build! Passed the smoke test first time it was plugged in.
Thanks a million!
Keith
My clock!
keithK5WX
Postby brand » Sat Dec 31, 2011 3:23 am
This is an elegant design and a very well organized kit. This was my first major solder work in about 30 years, and amazingly, it worked perfectly the first time. I'm sure that had more to do with the excellent instructions than my skill.
I made it for my brother-in-law, and since it wasn't ready for Christmas (I was taking my time), I'll send it to him next month for his birthday. Or course, after going through the forums, now I have to tempt fate and add the dimming, DST, and calibration features.
Thanks for making this available.
Take care,
brad
brand
Postby wd6cmu » Sun Jan 15, 2012 3:00 am
Ice Tube clock with ChronoDot for timebase and backup time maintenance.
wd6cmu
Postby physics_dude » Sun Jan 15, 2012 12:14 pm
This is not one picture, but around 1000 pictures, forming a timelapse.
It gets truly "dark and glowy" at around the 40 second mark.
Video: http://youtu.be/XLaBVkF_SyQ
physics_dude
PreviousNext
Return to Clocks
New Products [113]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
