still waiting the three (!!) clocks to arrive here in Germany ...
But maybe I've a trick to do the tube soldering. In the instructions "... bend the wires out to keep the tube in place and solder each wire ..." one should solder all wires.
What if one solders only one wire - the top one. Then align the tube again and solder the bottom wire. So the tube is horizontally fixed.
Next solder the right wire, align vertically and solder the opposite wire on the left. Now the tube is fixed vertically and horizontally.
If the alignment is not as good as you want - there are only 4 wires to unsolder or re-heat to correct alignment.
Now solder the rest of the wires.
I think, that will work perfectly.
Bye
Stefan
