Sure, I, er, um, meant to do that, whatever it is. (Note to self: check date on clock.)joerg.daehn wrote:For those of you, who haven't yet noticed: jsgf left a little easter egg in his firmware: just look at today's date . . .
ICE Tube Clock Firmware Comparison
Re: ICE Tube Clock Firmware Comparison
- joerg_daehn
Well here on April 1st it was April 0, 2010. I thought that was a nice easter egg. If it happened by chance, never mind.Sure, I, er, um, meant to do that, whatever it is. (Note to self: check date on clock.)
J.
Re: Firmware Comparison
I can only see the table in the blog post which doesn't have URLs of all the various firmware homepages. Are they posted in one place somewhere?bastard wrote:I added the URLs beneath the table for easy clicking.
I just uploaded a new comparison sheet. All firmware modders please let me know, if all your features are correct.
Bye
Stefan
Bye
Stefan
- ortsac
I am a novice here and have no way of updating the firmware nor the programming skills to do so. I am willing to buy an MCU that has all the latest firmware mods to the ITC (Ice Tube Clock) already burnt and certifiably verified working unit.
- wbp
ortsac - are you in the USA? If so, send me a chip and I'll program it for you. Probably best to take this to email: wm (at) usa (dot) net.
William
William
- jyohe
Say, William (wbp),
Have you considering putting your latest revision (mentioned here: http://forums.adafruit.com/viewtopic.ph ... re#p128768 ) up to the Firmware Comparison chart?
-Jim
-Jim
- crites
Can anyone point me to a link that will give me info on compiling these firmware packages the ICE Tube Clock?
Got my GPS running, now I think I need the dimmer function.
Thanks,
-TAC
Thanks,
-TAC
I've decided to make a clock with custom firmware as a gift for someone special, but after downloading the firmware mods from the board I was unable to compile on my platform. After some digging I realized that none of the firmware mods available here are updated for use with avr-libc 1.8.0. I decided to use DigiSage's firmware as my starting point and present here new version of DigiSage's code that is unchanged in functionality but will compile with avr-libc 1.8.0. Actually, all I can really say for sure is that it compiles with some warnings (didn't bother to correct those) on my Mac running 10.6.8 with Objective Development's AVR Crosspack 2012-12-07. I have also sent the firmware to my ice tube clock with avrdude and confirmed that it starts up and runs fine.
Like I said, it's a little ugly but it compiles on my machine now and I'm only uploading it because someone else might find it useful.
- Attachments
- firmware09-30-09-multipack-digisage-update.zip
- DigiSafe ice tube firmware updated for avr-libc 1.8.0
- (285 KiB) Downloaded 676 times
- jarchie
I am not aware of any such resource. If you have an ATMEGA328P-PU, I would recommend playing with my firmware. It has installation instructions, compiles cleanly, and the code is clearly written.Can anyone point me to a link that will give me info on compiling these firmware packages the ICE Tube Clock?
Some of the older firmware projects no longer compile on recent versions of GCC, so the code will need to be modified in order for them to compile. This is the procedure I used to get the Adafruit code to compile and run on my clock. The procedure for older firmware projects based on the Adafruit code should be similar.
EDIT: The version of GCC that comes with WinAVR is quite old, and these firmwares probably do compile just fine in that environment.
First, the original Adafruit Ice Tube Clock code defines several pointers in program memory which are not declared as constants. These pointers are alphatable_p and numbertable_p in fonttable.h as well as digittable_p and segmenttable_p in iv.c. Recent versions of GCC do not allow nonconstant program memory pointers, so each of these pointers must be declared constant. For example, the definition of alphatable_p should be changed to
PGM_P const alphatable_p PROGMEM = alphatable;
- SIG_OVERFLOW0 -> TIMER0_OVF_vect
- SIG_PIN_CHANGE2 -> PCINT2_vect
- SIG_PIN_CHANGE0 -> PCINT0_vect
- SIG_INTERRUPT0 -> INT0_vect
- SIG_COMPARATOR -> ANALOG_COMP_vect
AVRDUDE_PROGRAMMER = usbtiny
AVRDUDE_PORT = usb
Porting a firmware to the ATMEGA328P-PU is described in another thread.
Hope that helps. Happy hacking!
- windy48
Cool ICE Tube Clock,waiting for your complete.
Cause anyway I don't have any source of this.
Customized Anime Girl Case Fashion Cover For Ipad Air/Air 2
- Volodya
Hi. Please help me to solve the problem with compiling HEX files for ATMega328p firmware for your Ice Tube Clock project. I downloaded the source files (in the attachment), but I can not compile them - the command "Make" is interrupted with an error when processing the file time.If you still have ready HEX files for version (revision) "D" please send them to my e-mail ([email protected]). I would be very grateful. Thank you in advance. Sincerely, Vladimir.
The log of the command "Make":
orangepiplus:~/Desktop/firmware$ sudo make
avr-gcc -c -I. -mmcu=atmega328p -std=gnu99 -Os -Wall -DF_CPU=8000000 -o icetube.o icetube.c
avr-gcc -MM -I. -mmcu=atmega328p -std=gnu99 -Os -Wall -DF_CPU=8000000 icetube.c > icetube.d
avr-gcc -c -I. -mmcu=atmega328p -std=gnu99 -Os -Wall -DF_CPU=8000000 -o system.o system.c
avr-gcc -MM -I. -mmcu=atmega328p -std=gnu99 -Os -Wall -DF_CPU=8000000 system.c > system.d
./util.pl time | xargs avr-gcc -c -I. -mmcu=atmega328p -std=gnu99 -Os -Wall -DF_CPU=8000000 -o time.o time.c /bin/sh: 1: ./util.pl: Permission denied
time.c:25:32: error: ‘TIME_DEFAULT_AUTODST’ undeclared here (not in a function)uint8_t ee_time_status EEMEM = TIME_DEFAULT_AUTODST;
time.c:29:32: error: ‘TIME_DEFAULT_YEAR’ undeclared here (not in a function)uint8_t ee_time_year EEMEM = TIME_DEFAULT_YEAR;
time.c:30:32: error: ‘TIME_DEFAULT_MONTH’ undeclared here (not in a function)uint8_t ee_time_month EEMEM = TIME_DEFAULT_MONTH;
time.c:31:32: error: ‘TIME_DEFAULT_MDAY’ undeclared here (not in a function)uint8_t ee_time_day EEMEM = TIME_DEFAULT_MDAY;
time.c:32:32: error: ‘TIME_DEFAULT_HOUR’ undeclared here (not in a function)uint8_t ee_time_hour EEMEM = TIME_DEFAULT_HOUR;
time.c:33:32: error: ‘TIME_DEFAULT_MINUTE’ undeclared here (not in a function)uint8_t ee_time_minute EEMEM = TIME_DEFAULT_MINUTE;
time.c:34:32: error: ‘TIME_DEFAULT_SECOND’ undeclared here (not in a function)uint8_t ee_time_second EEMEM = TIME_DEFAULT_SECOND;
Makefile:67: BANNED BANNED BANNED для цели «time.o»
make: *** [time.o] BANNED 123
- Attachments
- xmas-icetube-master.rar
- The source files and schema of your project.
- (275.42 KiB) Downloaded 253 times
- jarchie
Looking at your output, the first error is
The default macros (TIME_DEFAULT_AUTODST, etc.) are all generated by util.pl, so the later errors make sense because util.pl failed.
So something is preventing the Perl script util.pl from running. Does util.pl have the executable bit ("x") set? If you run util.pl manually, you should see a usage synopsis.
If the executable bit is not set, try setting it with
Hope that helps.
time.c /bin/sh: 1: ./util.pl: Permission denied"
xmas-icetube/firmware % ls -l util.pl
-rwxr-xr-x 1 jarchie staff 6078 Aug 29 2014 util.pl*
xmas-icetube/firmware % ./util.pl
Usage: ./util.pl [time|fuse|lock|memusage]
xmas-icetube/firmware % chmod +x util.pl
- Volodya
Hello, thank you very much. Сommand: helped and compilation was successful. Today I'm going to flash the microcontroller. I hope everything works out.
If I have further problems when starting the clock, can I ask for help in the relevant sections of the forum?
xmas-icetube / firmware % chmod +x util.pl
- jarchie
Excellent! And congratulations on a successful build.
If you do run into any issues, I would be happy to help. It's probably better to post to the thread for my firmware rather than this one.
Good luck and happy hacking!
