First, I want to say my clock works, and is awesome. But...
I'm a noob and haven't had this problem. I went to put in D4, which is near the end of the instructions, and couldn't get the leg through one of the holes. I figured it was a blob of stray solder, but really I think it's a splinter of fiberglass. D4 isn't essential to the operation of the clock so it's not a fatal flaw but I would like to be able to use the battery, so: What's the best way to clear the obstruction? I couldn't just push it out of the way with anything small enough to ream out the hole.
Also, I'm not damaging anything by running without D4, right? I left the battery out of the holder.
Dreaded IceTube D4
Re: Dreaded IceTube D4
if you can push thru, try that?
I use the tiny dremel bits or sewing/quilting needles for clearing pcb holes, i do it by hand though, no mechanical force.
Mmm. Sewing needle is a good idea. I was trying a paperclip, but that's too big for that hole. I also tried (with pretty serious force) to push the part through, but the wire wasn't very stiff. A needle would be stiffer but also a good diameter.
- tcharron
I'm not sure which leg of the diode is the problem, and haven't looked at the board, but...
Is there anywhere else in the area that is electrically suitable for the connecton? I'd be inclined to just avoid using the hole if it was more than a 5 second fix.
you probably need to use those pads. we suggest just going for it!
