Digit 5 on VFD not showing up (Ice Tube Clock)
For RTC breakouts, etc., use the Other Products from Adafruit forum
skatterbean
Post by skatterbean »
Hi, been trying a couple of things to get digit VFD5 to light up on my VFD. I've resoldered, checked continuity. Everything checked out. I did the following continuity checks:
jumper pins to VFD wires (all check)
all VD driver socket pins (check)
all jumper socket pins (check)
I also checked continuity from the 6921 pin 20 (which I am to understand is VFD5) and I get continuity to a wire on the tube.
Anything else I need to check? Everything else checks out perfect, just this one digit isn't lighting up.
Jay
mike31416
Re: Digit 5 on VFD not showing up (Ice Tube Clock)
Post by mike31416 »
Please post a clear and detailed pictures of both side of the board.
Mike
Rotzog
Post by Rotzog »
Digit 5 is pin 17, Digit 6 is pin 20, counting from the right.
Return to “Clock Kits (discontinued)”
