help with monochron code
I'm trying to make some changes to the monochron code to allow the addition of new menu items in the config screen but I keep running into the same issue, the ticking clock next to the set time menu item is not easily moved. Where is the code that draws that on the screen? I need to be able to draw it one row higher or not draw it at all depending on what is going on.
Re: help with monochron code
thats in ratt.c in the timer code
I'm adding support for a "chime" on the clock. There are three chime settings, On (two tiny beeps on the hour), Off and Church Bell ( it rings once for each hour in the score ). I'm using your beep method in ratt.c to produce the audio but i'm finding that my beeping slows down/pauses the animation for a split second. I don't see this with the code that makes the alarm noise. What's the trick?
not sure. we don't use the hardware oscillator, but the timer should just 'run' on its own
