Ice Clock Build - tests with unflashed atmega
For RTC breakouts, etc., use the Other Products from Adafruit forum
figgyb
Post by figgyb »
I'm putting together 3 ice clocks but I haven't gotten around to flashing the at168's yet. I noticed that when testing the boost converter voltage according to the build page I don't have what I should, does the programming on the 168 need to be in place for the boost converter to work?
The initial low-voltage buzz test didn't work either, and I assumed that one was related to the unflashed IC's and kept going...
help?
figgyb
Re: Ice Clock Build - tests with unflashed atmega
Post by figgyb »
Well, I went ahead and did the obvious thing... flashed the 168... and now all is good :)
len17
Post by len17 »
figgyb wrote:Well, I went ahead and did the obvious thing... flashed the 168... and now all is good :)
Check out the Ice Tube "design" page to see why. :)
Return to “Clock Kits (discontinued)”
