Monochron RATT firmware question
by ekeefe on Thu Aug 05, 2010 11:16 am
Thank you for a really cool clock kit, I am a unique electronic clock collector. I never had the opportunity to purchase the original 'Pong' clock, so this was a great find.
I just built my monochron kit. I love the display and the case. Good job!
I thought the kit was going to be shipped with the TV tennis firmware, but mine has the XDaliChron firmware.
I downloaded the archive from github for the RATT version, but the .hex file in the firmware folder was also the XDaliChron. Is there a broken link? Am I doing something wrong? Is the .hex file for the RATT clock available pre-compiled?
I was able to down load the hex file to the clock so I know I have the USB/ARVDUDE stuff working. I followed the instructions.
Any help would be super.
Once again, thank you for such a great clock.
ED
ekeefe
Re: Monochron RATT firmware question
by adafruit on Thu Aug 05, 2010 11:23 am
Hi Ed. we had a bit of a mixup in the GitHub repository. its fixable but will take a day to clean up :oops:
however, so you dont have to wait, here is what SHOULD be the right .hex
please try it! :)
monochron.hex
TV tennis
(65.06 KiB) Downloaded 713 times
by ekeefe on Thu Aug 05, 2010 11:31 am
Thank you!
I downloaded the file and uploaded it to the clock. No problems.
Thank you so much for the quick response.
ED
ekeefe
by adafruit on Thu Aug 05, 2010 11:37 am
yay! we'll get this fixed properly asap
by dataman on Fri Aug 06, 2010 1:58 am
It's github?
Just backout, no?
Dataman
Charley Jones, crjones.com
Founder and President:
Sql Server Society of Las Vegas, SSSolv.com
XNA User Group, LVXug.Com
Las Vegas Make, LVMake.Com
Developer of the IntruderChron, MultiChron, & GOL 1.4 Mod, Crjones.Com/AdaMods
dataman
by adafruit_support on Fri Aug 06, 2010 5:11 am
For the time being, you can find the main RATT code on my fork, http://github.com/CaitSith2/monochron
I would have fixed the master branch, except that I no longer have write access to the http://github.com/adafruit/monochron (which I only found out when I tried to revert the master branch just now. :( )
adafruit_support
Site Admin
by caitsith2 on Fri Aug 06, 2010 2:46 pm
Okay, Master branch has been fixed.
caitsith2
by dataman on Fri Aug 06, 2010 3:30 pm
Can we perhaps negotiate promoting developer code fixes back up to the master branch?
I mentioned this code fix last October, and it went nowhere.
This is a bug, in a base library, doesn't really affect anyone but intruderchron,
But it's proliferating through the different versions now.
I'm working on combining 7 Chron, IntruderChron, and Ratt Chron into 1 version.
Change around the menu options, and you can select the display style.
And, if there's enough room, maybe Dali Chron as well.
glcd.c
Error in base library.
(7.23 KiB) Downloaded 191 times
Dataman
dataman
by caitsith2 on Fri Aug 06, 2010 6:52 pm
Okay, bug fix applied to all branches and forks under my control.
caitsith2
by caitsith2 on Sat Aug 07, 2010 5:43 am
dataman: You may wish to checkout the changes I recently pushed to ALL branches that I have write access to. I fixed a rare lockup bug in regards to setting the date and time.
uint8_t readi2ctime(void) {
  uint8_t regaddr = 0, r;
  uint8_t clockdata[8];
  // check the time from the RTC
  cli();
  r = i2cMasterSendNI(0xD0, 1, &regaddr);
  if (r != 0) {
    DEBUG(putstring("Reading i2c data: ")); DEBUG(uart_putw_dec(r)); DEBUG(putstring_nl(""));
    while(1) {
      beep(4000, 100);
      _delay_ms(100);
      beep(4000, 100);
      _delay_ms(1000);
  r = i2cMasterReceiveNI(0xD0, 7, &clockdata[0]);
  sei();
  if (r != 0) {
    while(1) {
      beep(4000, 100);
      _delay_ms(100);
      beep(4000, 100);
      _delay_ms(1000);
  time_s = ((clockdata[0] >> 4) & 0x7)*10 + (clockdata[0] & 0xF);
  time_m = ((clockdata[1] >> 4) & 0x7)*10 + (clockdata[1] & 0xF);
  if (clockdata[2] & _BV(6)) {
    // "12 hr" mode
    time_h = ((clockdata[2] >> 5) & 0x1)*12 +
      ((clockdata[2] >> 4) & 0x1)*10 + (clockdata[2] & 0xF);
  } else {
    time_h = ((clockdata[2] >> 4) & 0x3)*10 + (clockdata[2] & 0xF);
  date_d = ((clockdata[4] >> 4) & 0x3)*10 + (clockdata[4] & 0xF);
  date_m = ((clockdata[5] >> 4) & 0x1)*10 + (clockdata[5] & 0xF);
  date_y = ((clockdata[6] >> 4) & 0xF)*10 + (clockdata[6] & 0xF);
  return clockdata[0] & 0x80;
void writei2ctime(uint8_t sec, uint8_t min, uint8_t hr, uint8_t day,
        uint8_t date, uint8_t mon, uint8_t yr) {
  uint8_t clockdata[8] = {0,0,0,0,0,0,0,0};
  clockdata[0] = 0; // address
  clockdata[1] = i2bcd(sec);  // s
  clockdata[2] = i2bcd(min);  // m
  clockdata[3] = i2bcd(hr); // h
  clockdata[4] = i2bcd(day);  // day
  clockdata[5] = i2bcd(date);  // date
  clockdata[6] = i2bcd(mon);  // month
  clockdata[7] = i2bcd(yr); // year
  cli();
  uint8_t r = i2cMasterSendNI(0xD0, 8, &clockdata[0]);
  sei();
  //DEBUG(putstring("Writing i2c data: ")); DEBUG(uart_putw_dec()); DEBUG(putstring_nl(""));
  if (r != 0) {
    while(1) {
      beep(4000, 100);
      _delay_ms(100);
      beep(4000, 100);
      _delay_ms(1000);
Specifically, the problem lies in those two functions. The i2c library does NOT disable all interrupts, just the ones specific to i2c itself, when using the No interrupt version of the i2c calls. Of course, if one of the interrupts you didn't disable happens to call readi2ctime, while the processor happens to still be inside of i2cMasterSendNI in the writei2ctime function, then yeah, bad things happen, that lead to a total lockup.
This affects ALL branches. Since I don't have write access to your fork, I can't fix the bug for you, but you should be able to do that very easily.
caitsith2
by dataman on Sat Aug 07, 2010 4:53 pm
Cait,
Thank you for the heads up!
Pretty soon, we won't need no stink'n branches.
Check my next subject, MultiChron!
Dataman
dataman
by surfjunkie on Thu Jan 17, 2013 11:07 pm
Help! I have my clock built, I was able to get the FTDI to link up and talk to my clock, but when I add the file to write....it comes up with a "parse error". I am either not copying the right file to managing the the file upload right....can someone guide me through this?
I am nearly there...I am just flubbing up somewhere. Help if you can.
surfjunkie
